outside wind noise, 2000 Maxima
This isn't a "problem", more an irritant. With everything closed up tight, and at highway speeds, I get quite a bit of outside wind noise coming through the driver's side window area.....more than a car of this caliber should have in my opinion. As far as I can tell, it appears to be coming from mostly around the top, rear corner of the window. Is there some kind of layman's "fix" for this? All suggestions appreciated. Thanks everyone!
PS....I love this forum and have learned a lot from reading it! |
There is probably to much clearance between the glass and the run-rubber. There is a bulletin for the rear windows, but you can also use the same repair instructions for the front windows: Service Bulletins Nissan Cars
2000, maxima, noise, wind |
