2007 SL 120k miles ABS system Failure
I have had my 07 Maxima into the dealer recently and wanted to summarize the issues.
2 Years back ABS light came on. Dealer wanted $3000 to fix it so I have been driving without ABS. One month back the car started to experience intermittent acceleartyions issues. For example trying to get on expressway, the car would not get above 35-40 even with the RPM at 4k I tool to my dealer and the car had no codes. They said to take to nissan as they do not work on CVT. $500 later, the dealer ran some codes and looked up the NTB. -ABS controller is not responding across the CAN. -Speed sensors need to be replaced. -No issues with CVT Cost to fix $2500 on top of the $500. I spent the easter weekend replacing the ABS module and speed sensors ABS module was hard to find for the 07 that is same module #. 47660 ZK40A is common but not the 47660 ZK30A Finally found a donar vehicle after 4 hrs. Front sensors where easy. Rear I took recomended precautions, but still snapped one bolt. Will figure out the fix latter |
RE
So after 8 hrs if work, I still have following
From Key on I have Slip and VDC Off lights After moving 10-15 ft the ABS and brake light come on For codes, recall I had no codes before with hand scan tool Now I have U1000, and C1124 and C1155 with hand scan tool Scan tool says C1124 is Shaft speed signal, but online it says brake fluid level. The brake lines where bleed after module was replaced and the fluid is full C1155 says Front wheel sensor so I need to recheck So now for question. I assume no need to flash the ABS module or clear the U1000. Should I go back to the dealer to have them rescan, or should I tear the nuckle down and do a deep cleaning. I wish I had an alternative to the dealer as they clearly have no experience with this issue. I would be fine to getting back to no ABS, but the lack of acceleration is something I need to resolve. |
120k, abs, failure, miles, system |
