ABS activates without brakes and shows no codes Forums > > ABS activates without brakes and shows no codes ABS activates without brakes and shows no codes
Old 12-07-2018, 09:32 AM
Brendan Ternes Brendan Ternes is offline
2006 Maxima
Default ABS activates without brakes and shows no codes
2006 Maxima sounds like the ABS is activated even when not applying the brakes.
135,000 miles
Old 12-15-2018, 04:47 AM
Check for play in the wheel bearings and for debris stuck on the ABS wheel speed sensors that could be causing a short to the ABS sprocket.
Old 12-15-2018, 12:16 PM
135,000 miles
If you use the search function on the forum you should be able to find all of the info you need to fix this problem. It has been discussed several times.
Here is one of many:
https://x.nissanhelp.com/forums/maxima/9112-06-maxima-abs-issue-4.html
abs, activates, brakes, codes, shows
Copyright ©2000 - 2019, vBulletin Solutions Inc.
Search Engine Optimisation provided by DragonByte SEO v2.0.42 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
