2000 A32 CEFIRO.  No Ignition pulse on cylinders 2 & 3. Forums > > 2000 A32 CEFIRO.  No Ignition pulse on cylinders 2 & 3. 2000 A32 CEFIRO. No Ignition pulse on cylinders 2 & 3.
Old 11-25-2018, 12:03 AM
Max in Thailand Max in Thailand is offline
2000
2000 Cefiro VQ20de
Default 2000 A32 CEFIRO. No Ignition pulse on cylinders 2 & 3.
Hi, I have a strange fault with my Nissan Cefiro A32 VQ20de 2ltr. Year 2000, with auto box.
I live in Thailand during the winter & while I was away in the summer the wife cooked the engine. This was due to radiator fan failure. Great!
She had it rebuilt by a local garage without telling me & it ran fine for about a month. Then the problem started just before I returned.
On my return to Thailand she told me about what had happened. I was not happy. I found the garage had put the wrong plugs in to start with & she wonít say which garage she used.
Now the car is not firing on cylinders 2 & 3. Iíve done all the usual checks like changing around COPís, checking wiring for shorts or open circuit. Nothing.
Now I used a Scope on the output pins from the ECU to the COPís to find that there is no pulse to both cylinders 2 & 3. All the others are just fine.
Before I left Thailand, the car was getting harder to start when hot. But it ran fine once started.
I got myself a code reader to see what codes I had & the original fault codes where 21 & 34. (Ignition Signal circuit) & (Knock sensor Circuit). When I changed the Knock sensor these disappeared. Then code 52 came up. (NO Faults).
But there is still a fault that the ECU is not seeing.
Now I donít know if Iím right in saying that this old ODB system (14pin) does not check Outputs but only Inputs. If that is so then it would explain why no other codes show up. Maybe someone could update me on this info if Iím right or not.
I read on the internet of a guy with the same fault as I have on his Maxima. He was asking one of these so called, ĒOn-line mechanicsĒ. The guy had tried his ECU in another car & it worked fine. But would not work in his car. He had the same fault as me.
He left the so called mechanic without getting an answer.
Now I donít have another car to try it in, so thatís out of the question.
The ECU is a 23710-45U62 (A18-F96) with big letters D3 on it. I understand that ecuís with U12,U61 or U62 will fit this car but I canít find any anywhere. Unless some one knows different.
So any help would be most appreciated.
Old 03-14-2019, 06:37 PM
2000
2000 Cefiro VQ20de
Hi everyone, Just to update you all. I managed to get a ECU replacement from China & when fitted, I still have the same fault.
It looks like I wasted my time on this forum, not a single reply with anything useful. Thanks a lot everyone.
a32, cefiro, cylinders, ignition, pulse
