DTC P1320: Ignition signal
Hi, having trouble with my new(used) 2000 Maxima SE.
Car runs like a top, sounds great, no rpm drops or misses. However, car illuminates CHECK ENGINE, SLIP, TCS lights. Ignition coils have been done with upgraded green stamped MOE parts. Mass airflow sensor is also new and the car has been into the dealer 3 times with no success. They want to replace the harness for $4500 and I'm not falling for that scam. I've read some forums and suspect ingnition condenser. Does anyone know correct Ohm reading condensor should give? Or has anyone encountered this same problem and offer suggestions on the most likely culprit. |
Before replacing any more parts I suggest measuring all the signal from the ignition coils with an oscilloscope.
dtc, ignition, p1320, signal |
