2001- Max GLE Gauge Cluster-Dies in the heat
The instrument gauge cluster, all gauges includig odo, trip, fuel, temp, tach, and speedo die in the heat. The cruise controller will also drop out and flash. In the winter it usually is ok but still can happen. Sometimes the tach and / or speedo run up the dial and pin. When parked in the hot sun nothing works except the parking brake light, good old check engine light (that always works).
The heat issue seems to be related to the engine compartment not the cabin. Might be worthwhile cutting into the wiring harness at the wye connection near the right front strut tower. Last edited by richardengineer; 09-07-2013 at 07:30 PM. |
2001, clusterdies, gauge, gle, heat, max |
