2001 Maxima - Ignition Coil Connector
I need some help. I'm in the need of the connector to the ignition coil. The ignition coil is the male piece. I need the connector (female piece). I need two of them. The connecting clips broke while I was removing the coil to replace the spark plugs. Anyone can help me find where to order them from? I really do not want to resort to finding them at a junk yard, due to I will probably run into the same problem. Them breaking again.
Thanks in advance for your help. Mike |
The easiest way to get a new connector is probably the dealer.
You could try finding the one you need from here: Connectors I think the one you need is J-48817-102 (Page 38). If that is the correct connector you can order the connector from here: https://tools.nissantechmate.com/en-US/Pages/Home.aspx Again, the easiest way to get the connector is probably the dealer or the junk yard.
2001, coil, connector, ignition, maxima |
