2000 maxima cold days starts but dies
Need help I have a 2000 maxima se, when u start car in the cold weather the car die when the idle drop and when the motor is warm then its fine. Hope someone can help thanks.
You could start by performing the Idle Air Volume Learning Procedure. Instructions here: 2000-2001 Nissan Maxima Idle Air Volume Learning Procedure | Nissanhelp.com
Thanks ill try that and see how it work. Anything ill repost :-)
Hello Nissan tech I did what u said n everything came out normal to where it needs to be. Is there anything u can suggest for me to check.
Thanks |
You most likely need a new idle air control valve
tcs n service light on
Please help when my tires went bad the tcs light came on. Now I have new tires on n the car and light is still on. Does it reset itself or is there something wrong?
Bad tires will not usually cause the TCS light to set. You'll need to have the TCS codes retrieved. These will need to be retrieved using a capable scantool; the generic OBD II code readers many part stores used to pull codes for free will not work on TCS systems. The stored code(s) should have shed light on what the problem is.
2000, cold, days, dies, maxima, starts |
