Please help!
I have a 2000 maxima. It has no check engine light. What it does is between 20 and 50 mph it will surge [rpms jump up and down] but not all the time its just intermittent. And sometimes hard to crank. New plugs, it had a new maf about 4 years ago and it stopped for a while but then started back. I checked the wires to the maf and all within specs. Its a aftermarket maf. Ive read about the pcm needing to be flashed, but if it does why would it drive okay for a year or so and then start messing up again, wouldn't it drivd worse as soon as it was replaced. Could it be tps????
check all your vacum hoses for cracks in then around the intake manifold...Ray
I would be suspicious of an aftermarket MAF, as problem sounds like what mine was doing when MAF bit the dust. I replaced with a refurbished OEM MAF from autopartsexpress.com (about $160) and a new isolator ring from the dealer (about $10) some 18 months ago and it has been fine ever since.
1997 Maxima SE, 5 speed, dark green with tan leather, 235K+ miles and still going strong. |
I am suspicious of the aftermarket MAF. Your problem sounds just like mine was doing about 18 months ago. I put in a refurbished OEM MAF from autopartsexpress.com (about $160) and a new isolator ring from the dealer (about $10) and the problem was solved. Vehicle has been running fine ever since. Good luck.
Also clean and check your IAC.
maf, surges |
