key position checking codes
after i printed off the diagnostic procedure ,it says to have the key off.but dont you need the key on the run position to check for power.And have the key off to check the grounds? is there a spot to checck that shows where all the connectors are and there number so i can find them whne the manual says to locate a specific connector?
thanks |
checking, codes, key, position |
