2000 Maxima engine miss bad motor mount Forums > > 2000 Maxima engine miss bad motor mount 2000 Maxima engine miss bad motor mount
Old 07-22-2011, 12:08 PM
archies351
Default 2000 Maxima engine miss bad motor mount
ok i have a 2000 maxima that has a bad front motor mount with wires coming out of it and cyl 4 miss fire (injector not firing) over laid wire to ecm fixed the engine miss. my question is
Can the bad engine mount cause the miss? and when I replace the mount to i need to buy the one with wiring or just buy the standard on
Old 07-22-2011, 11:13 PM
I have seen the mounts burn the ECM, but usually when the ECM is burnt out the engine will no run at all. I never seen a mount cause a misfire.
You can buy and install a mount without the wires. Disconnecting the mount will cause no problems.
Old 07-23-2011, 06:08 PM
archies351
thanks for the info
2000, bad, engine, maxima, miss, motor, mount
