no heat in maxima;nissan
heat system blowing cold air. What could cause that? I had thermostat replaced, still heat not working.
There are many things that can make the heater not working properly:
- Air in the cooling system - Clogged heater unit - Bad thermostat - "Mode Door" may be stuck in the cooling side. - "Mode Door" actuator may be bad - No power to the mode door actuator - Bad sensor (if auto) Do you have any engine cooling system problems? Are you able to change the temperature? (from very cold to no as cold) Do you have a manual or auto A/C system?
heat, maximanissan |
