P1605 - 2001 Infiniti I30
Ok guys thanks for check out my thread. I have a DTC p1605 A/T Diag comm line. I have replaced the TCM with one from a 2000 p/n: 31306-3Y300. The one that came out of the car orignially was p/n: 31036 5y001. I am still getting the same trouble code, could it be that they are infact different TCMs and will not communicate properly?
My other option is I have another 2001 maxima and I am going to swap out the TCM from the 01 Max to the 01 I30 and see if it goes away finally. THanks for your input |
There is a bulletin for that code. The bulletin suggest replacing the TCM with the 31036-5Y001, which is the one you originally had in your vehicle.
Knowledgebase - 2001 I30 - Infinitihelp.com Forums Did you erase the code in the TCM and the ECM? if you did and you already had the new TCM, then you may have a broken wire between the ECM and TCM. There is also a bulletin for the 2001 Maxima (Knowledgebase - 2001 Maxima - Nissanhelp.com Forums) but the part numbers are different. 31036-4Y901
2001, i30, infiniti, p1605 |
