how to replace a back up light switch
need some instruction on how to replace the back up light switch. thanks
Hello
:oops: I fail to ask you if you have a manual or auto transmission. (see figure 2) If is automatic the backup light is controlled by the inhibitor switch and it may just need to be adjusted, If is a manual transmission, just locate the switch and replaced. (see figure 1 for location)
where is figure 1 located?? under the hood? or in the rear of the car... can't make out what that is a picture of!?
Would it be the back up light switch or the pnp switch.....i say that because i have a 5 speed....a mechanic i went to said it wasnt the pnp it was the back up light switch...Nissan Tech can u show the skematics for the placement of the back up light switch or is that it above this post?
Oh btw...my code is P0705....for a 5 speed transmission
And would this be the back up light switch??
96 1996 Nissan Maxima Back Up Light Switch - Body Electrical - Beck Arnley, Standard Motor Products - PartsGeek |
Did anyone actually locate the back up lamp switch for a manual transmission hardbody? 1996.😏 Thanks!!!
back, light, replace, switch |
