my 98 maxima wont pass inspection due to service engine light . the codes are po141, po325, po110 and po105. i'd appreciate any help
Start by checking the description of each code here: Nissan OBDII Code Chart P0000-P0175
Since the codes are for different component try disconnecting the car battery to erase the codes (or erasing all codes with the scanner) and check which codes comes out first, fix it and try again. I do not recommend replacing all the components at once.
Ok got the codes . I'll try the procedure. Thanks
codes, max |
