instrument Cluster Forums > > instrument Cluster instrument Cluster
Old 01-21-2009, 07:54 AM
wismo
Default instrument Cluster
Hi my speedometer quit working so i took the cluster out and on the back the copper trace is burned. So i tried to solder it back together and it worked for a couple minutes then started smoking.
I guess my queston is if i get another cluster is it likely to also burn at that spot or could this just be defective OR what could cause this...
I just dont want to ruin a good cluster immediatly upon install...
Thanks in advance for any help or suggestions Bill
instrument Cluster-s1030989-jpg
Old 01-21-2009, 04:16 PM
tech22's Avatar
tech22 tech22 is offline
2005 Frontier Crew Cab Frontier Crew Cab
05 nissan frontier
The maxies have been good to the clusters and i for one have never replaced one that was burnt out due to and outside electrical spike.
Old 01-22-2009, 08:43 PM
wismo
so the replacement cluster should be ok?
Old 01-23-2009, 06:04 AM
wismo
well i got a salvage cluster and it burned out in the same place..
I checked for melted wires as far back as i could see in dash>
Can some one plese help me trouble shoot this.Or give me a possible starting point..Thanks Bill......
Old 01-23-2009, 10:12 AM
tech22's Avatar
05 nissan frontier
Sorry i cannot look at the service manual as my data base only goes back to 94. I would start by taking a close look at the harness for a cut that is contacting metal. then take voltage readings at the connector. Without a wiring diagram i can't say for sure just what the voltage input is. Maybe another tech will respond that has a manual for that year.
Old 01-23-2009, 10:52 AM
wismo
Thanks I will start there. Ill probably have to buy a 1992 manual or do alldata.
As far as that connector goes does it go from inside through firewall out then back inside to a computer.
Old 01-24-2009, 06:10 AM
tech22's Avatar
05 nissan frontier
Not sure how they routed it.I want to say it is routed down the right side and under the front door sill plate and then out to the trans,but really not sure on that year.
Old 01-24-2009, 06:55 AM
wismo
I just remembered over the summer (yeah its been months since i had a speedometer) i was driving highway speed and the car lost a lot of power when i pulled over the car would not start the fuse marked ENG CONT.was blown.I replaced it but no speedometer since.
And I ve replaced sensor.
I dont see any burnt or nicked wires. Maybe someone can point me in the right direction knowing this. Im sick of looking at wires and its cold outside:
Old 01-24-2009, 10:44 AM
wismo
well I think I figured it out. I had done the vtc rewire when i bougt the vehicle. I disconnected that resoldered the broken trace in back of speedometer and its working. Thanks everyone...
Old 01-24-2009, 03:04 PM
tech22's Avatar
05 nissan frontier
Great. I'am glad to hear you got that sorted out.
cluster, instrument
Copyright ©2000 - 2021, vBulletin Solutions Inc.
Search Engine Optimisation provided by DragonByte SEO v2.0.42 (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
