Help with O2 Readings Needed
Background - this is my daughters 2001 Nissan Sentra GXE that she drove with a missfire due to a faulty ECM. I replaced the ECM and now the check engine light is on. I originally thought she fried one or both of the catalytic converters. The fault code is P0420 catalyst efficiency bank 1 but, aren't these good readings for B1?
B1 S1 .13 to .72 VDC STFT B1 S1 -2.3 to - 5.4% B1 S2 .13 to .14 VDC STFT B1 S2 99.2% (cycles between rich and lean but mostly lean) B2 S1 .11 to .61 VDC STFT B2 S1 -.7 to -3.1% (reads lean) B2 S2 .12 to .16 VDC STFT B2 S2 99.2% (cycles from rich to lean) Can anyone advise on the condition of the O2 sensors and catalytic converters given the above info? The car has two converters and I assume the first is a precat or bank 1. Thanks for the help. |
The convertor is attached to the exhaust manifold on this model. You want to monitor the sensors in a line graph to see what the pattern looks like. If the pattern on the rear o2 sensor start to mimick the front then you have a bad cat. The rear sensor pattern should be almost a straight line until you snap the throttle and should only increase momentarily and go back to a straight line.
Doesn't the steady voltage output of sensor 2 indicate the cat is doing its job? Thanks.
This vehicle has B1 and B2 convertors side by side directly off the manifold. They can not be separated. |
Since the ECM has been replaced on the car would be of any value to have the unit reprogrammed. I understand the ECM can become over sensitive and give false PO420 codes.
Thanks for all your helpful answers. Walt |
