01 pathfinder with electrical ghost please advise
I just purchased an 01 pathfinder and have had assorted fuse issues. It appears that there has been body work done on the drivers rear. I am assuming that I need to take the taillight assemble out to inspect. first blew the brake light fuse which causes the shift lock to operate replaced the fuse and then it happened again but also took out the tail light fuse. I have replaced the fuses. I have lost lights behind the speedometer, tachometer, fuel and temperature gauges. and am not sure where they are tied into. any suggestions would be appreciated. I am not close to a Nissan dealer at all. thank you
Intermittent short circuits are the worst, specially with body work. Unfortunately there is no much I can recommend from here, other than take as many parts as you can, and try to visually inspect the wires. Obviously I'll start in the area of the body work. Good luck.
Does the vehicle have a non factory trailer wiring harness. I have seen the convertor box short out and pop fuses for the lights.
if it has the old style 1157 bulbs i have seen the contacts on the bulbs melt and touch together causing these kind of problems by making a path straight to ground. if it has 3157 bulbs then this is probably not the problem. they changed around that time.
the trailer harness appears to be original ad in good shape with a cover. I have used it to tow and all seems well. Thank You for your help.
i'd also start checking all the grounds and any loose wires. |
Look for the convertor box for the trailer wiring. It is usually located by the hitch itself (rectangular box with wires coming out of both sides) it is usually pretty obvious if it has shorted out. The box will be distorted ofrmay have a hole melted right through it.
