P0745 Pressure Control Solenoid Malfunction
Can some one tell me what this part is? What is does? Where is is located? My o/d light flashes 16 times when I turn car on then goes off. There is a Code P0745. I tryed to check code by turning car to on position and following all the steps but the ses light never blinks. Help:confused:
3 Attachment(s)
The Pressure solenoid is inside the transmission and it helps regulate the pressure from the trans fluid pump.
There is also a "Dropping resistors", that controls the voltage from the ECM to the solenoid. If the resistor fail, it can also trigger the same code. The resistor is located in the engine compartment. Before removing the transmission valve body to inspect the solenoid, you should inspect the resistor and replaced if necessary. |
Thanks for the help
I just want to thank you for the help. I also wanted to let others know what the out come was. I was getting the code P0745. My mechanic said it wasn't the transmission or the wiring harness. The problem was under the dash a swith that converts 12 volts to 8 volts for the computer. Can anyone tell me more about this?
Switch
It was on the trans computer the blue rectangle box it has a silver attachement the resistor that was the part. Does that make sense. He said something about my wires running to this part were old and the new tranny parts were it better condition something about ohms.
It doesn't make sense, sometimes we, the mechanics, don't like to admit we did something wrong and we blame another part :-). I personally don't do that but I have seen other techs doing it ;-). I'm glad he fix the problem for you.
95 altima tranny issue
I seem to have a similar problem with my 95 Altima GXE. When I start the car the o/d light flashes 16 times but the service engine soon light is not on. Does this mean I have the same problem and should I seek my normal mechanic or a tranny specialist? Also when starting from a stop the car is pretty sluggish so it's obviously tranny related..hopefully nothing too serious! Thanks!
japapoe, you should check the transmission control unit for codes. Some AutoParts can do it free for you.
can you show me a diagram of the "Dropping resistors", that controls the voltage from the ECM to the solenoid, to see if I can find and replace?
2 Attachment(s)
mine is throwing a p0745 code and i'm wondering what options i have the car is shifting hard between first and second . would it be cheaper to buy another tranny and replace it or try to take the old one out to replace the solenoids. or do you have to pull the tranny out to replace them. i will be doing the work myself to save on labor. thanks
can some one tell me how much will it cost for the pressure control solenoid.
what is p0325 knock sensor 1 circuit malfunction,it is on my emission inspection diagnostic report ,may i please know about this and price for this.
my service engine soon light is on and in the diagnostic report it says p0325 knock sensor 1 circuit malfunction and p0745 pressure control solenoid malfunction,what will be the best solution ,will replacement of these parts solve the engine light problem too.
Does the transmission shift hard? |
