2001 Maxima GLE Rear side marker lights
How do you change the rear side right and left marker lights on a 2001 Maxima GLE?
2 Attachment(s)
If you just need to replaced the bulbs, remove the trunk trims to access the bulbs.
If you need to remove the lamps, you need to remove the trunk trims to access the nuts that hold the lamps in place. Once the nuts are removed you can pull out the lamps. |
wrong lights I need REAR SIDE MARKER LIGHT not rear tail lights
