Rough Idle on 2008 COupe
I have had a rough idle on my coupe since after 1 week of ownership (Sept 2). It has been brought to the dealer 5 times and they say that all codes match up. I have even got a case with Nissan North america which is getting me nowhere.
I am very frustrated and wonder if ANYONE else has this problem with the coupe. Other than the idle, everything else is great and I love this car. I just brought it to an independent Nissan tech and he does acknowledge that the idle is rough and that I need to INSIST that Nissan do something about it. Easier said than done. HELP!!! |
I have the SAME issue!!!! Mine is a 3.5 SE
Rough Idle on 3.5 coupe
So have you brought it in to Nissan at all and if so, what did they tell you???
At this point, I am taking it into the 3rd different dealership to see if they happen to have a tech that knows what to do. So far all they tell me is, "all of the codes check out'. Well then the car's computer must be bad. |
Rough Idle
By the way, I also have the 3.5 SE
i have the same problem with my 04 3.5 maxima...im running around 1000 rpm on idle sometimes...i have a check engine code that been on and off for a while...p1273 is da code but i dont know if that has nething to do with the idle because i already replaced my a/f ratio sensor and the MAF...any suggestions????
Update on rough idle problem
Well I have been told by 3 Nissan dealerships that you can't adjust the idle on this car.
Guess what? I JUST HAD IT DONE by Precision Z a Nissan mechanic that works specifically on Zs AND on NISSAN dealership owners cars (because they don't trust their own mechanics!) My ROUGH IDLE IS GONE after 5 months of anguish dealing with the dealerships and Nissan NOrth America. SO don't let them tell you it can't be done!! |
Care to post how he did it?
I took my car to the stealership today. I', trying to get info before they say "can't be done" |
Rough Idle
I can't wait to here what they have to say. Be sure to post it.
Rough Idle
I missed your first question about how he did it.
He is a specialist on Zs but also works on all Nissans. He has the same 8,000.00 laptop (from a manager friend of his at another local Nissan Dealer) computer that all of the Nissan techs use except that he and his partner know how to dig in and adjust things with a little brain power. (been in business since 1980 and his partner has been a tech for over 15 years) AND NIssan is trying to get him to be one of their Independent Mechanics. He just can't believe that Nissan wouldn't do it for me. He said that they just stick the thing into the dash and if no codes come up, all must be OK. There lies the difference. These techs don't know a WHOLE lot. So I wouldn't be surprised if you ran into the same response from the stealership. |
the idle and timing can be adjusted with the nissan tool but not suppose to tell customers about it doh! but i have in the past adjusted these items when no other problem is present.....by the way is one of the motor mounts broken?
Rough Idle
They (Nissan Techs and Precision Z) are all telling me that the motor mounts are fine. I know that WAS one of the possible culprits. Hope they are right!
Well... they DID take the roughness off on my car, and actually the gas milleage improved slightly.
Rough Idle
What did they do to take it away???
They said that the timing was off, so they adjusted it. And just like that, the problem was gone.
