thermostat on 97 NIssan Pathfinder
Can anybody tell me where to find the thermostat on 97 NIssan Pathfinder?
perhaps a diagram, how to change? |
REMOVAL
1. Drain engine coolant from drain plugs on radiator. 2. Remove radiator hoses (upper and lower) and fan shroud. 3. Remove drive belts. 4. Remove pulley bracket. 5. Remove water inlet and thermostat assembly. http://www.nissanhelp.com/images/image002.jpg INSPECTION 1. Check valve seating condition at ordinary temperatures. It should seat tightly. 2. Check valve opening temperature and valve lift. 3. Then check if valve is closed at 5°C (9°F) below valve opening temperature. INSTALLATION 1. Install thermostat with jiggle valve or air bleeder at upper side. 2. When installing water inlet apply liquid gasket as shown. After installation, run engine for a few minutes, and check for leaks. Be careful not to spill coolant over engine compartment. Use a rag to absorb coolant. http://www.nissanhelp.com/images/image004.jpg |
thanks you guys it seems a little more arduous than i anticipated but i think this is a great site!
You may try to look at this guide for repairing nissan: replace thermostat... Nissan Repair: re: Replace Thermostat, nissan maxima, radiator hose hope that it may help you a little guys.... _________________ Thermostat |
Just call its service center.
