2003 Nissan Maxima Service Manual
A new entry has been added to Knowledgebase
Description: 2003 Nissan Maxima Service Manual - All Sections - ZIP Compression To check it out, rate it or add comments, visit 2003 Nissan Maxima Service Manual The comments you make there will appear in the posts below. |
how do i download the 2003 nissan maxima service manual, thanks merry christmas
Now, IF the Section you need isn't loaded you can Subscribe ($10) and download anything you want (including your complete Service Manual). Or, you can wait a while until NissanHelp loads up the rest of your Service Manual Sections. Hope this helps... |
okkkkkkkkkkkkkkkkkkkk
[Check Engine Soon] Light
hello, i just bought a 2003 maxima se from a used car lot. the 'check engine soon' light came on & the indicator light (below techometer) reads 'tds 150' and then the 150 kept dropping (it's now 'tds 145'). what does that mean? please help. thanks!
(check engine soon) Light
Not sure if your question was answered or if you have solved your problem, but I have never seen a 'tds' light or comment in the 'Trip computer' screen. The closest display I see is 'dte' which means Distance To Empty. This is an estimate of many miles or kilometers that can be driven before re-fueling takes place. As for the 'check engine light' you will need a OBDII code reader/scanner to learn what 'code' is causing the light to come on.
