sentra gxe 1.8 l ignition coils
ref misfire #1 cyl
It appears two of my coils Or Cyln # 1 was not firing & #3 partially firing , but I try to verify a good one & supposly a bad coil and i get the same ohm readings. I try to to see if i get spark by the DTC procedure and nada. I am a puzzled . There are three leads /conections one marked + , the middle is G, the third one is lB . can some one give me some advice on this or diagram of the coil ref engine firing order 1342 I pull the harness off each injector while the car was running. only # 1 seem to be not working, i checked for spark on # 1 & 3 got nada if I tried to check #4 or #2 the car would not start and since I am by myself at the moment no one to help crank the engine. I swithed # 2 coil to # 1 cyl and the car ran Coil Data Primary is 1.0 ohms secondary is 10 K ohms Ignition Resistor 2.2K ohms I am puzzeled, At $100 a pop for the ignition coils, I have not satisfied myself I have found the problem Any advie or help would be greatly appreiciated. Lee |
Admin/moderator where are you?
any one know where the fuel filter is at on this car?:surrender:
5 Attachment(s)
Pulled from your Service Manual - Section EC ENGINE CONTROL SYSTEM and Section FE - ACCELERATOR CONTROL, FUEL & EXHAUST SYSTEMS Hope this helps... |
Lee, you should download the "Engine Control System" section of the service manual. Page EC-549 explains how to inspect the coils and the ignition system.
You can download the section from here: http://x.nissanhelp.com/forums/Knowledgebase/links/113 |
coils where bad
hey thanks for all the help
coils form cyl 1 & 2 where bad:confused::sweatdrop: replaced them to day, car now runs fine:clap: Lee:yes: |
