Wiring Diagram- 98,99,00,01 Mass Airflow Sensor
Does such a diagram exist? I messed up the 3 solder joints and resistors when trying to remove the sensor the incorrect way...should have researched it first. So, before I shopped for a new one, if I knew the value of the resistors on the cct board I could possibly repair it at my workplace.
Thanks This is my first post by the way.:clap: |
The diagram shows the connection of the air flow meter to the ECM, ground and power, but it doesn't show the values of every component. You can get the diagram, by downloading the "Engine Control" section of the service manual here: Knowledgebase/links/20/
