Derick |
04-15-2017 04:21 PM |
Engine smoking
So I have a 2004 frontier. there was a small amount of smoke coming from the driver side exhaust manifold. I could see a bit of oil dip from the valve cover onto the manifold. did a code check. did not bring up any codes. (the smoke is burnt oil. not exhaust or coolant)
I removed the upper intake manifold. removed and cleaned the the valve cover. replaced the gasket. Put everything back together. replaced the spark plugs and wires. (#6 was very painful.)
now it doesn't run right at all. multiple misfire code with a check engine light. still smokes. any help would be greatly appreciated.
