Wiring diagram
Hey, fellas. I need a wiring schematic for the cooling fans on my Sentra. To refresh, it's a 93 XE coupe with the 1.6L and two fans in the front. There are four wires on the harness and I need to know what each one is.
I will look but I am not sure if we have any manuals for that year. I think they all got boxed up. If asist goes back to 93 I should be able to get you something.
The electronic manual only goes back to 1994, but you can use the 1994 diagram it should be the same. You can find the cooling find diagram in the "Air Condition" section Page 44. Just uploaded for you.
Sweet. Thanks, guys.
FYI: I still have a service manual (hard copy) for the 1984 Sentra, if a need/question comes up.
I eyeballed the manuals and didn't find wiring schematics for those fans. FieldRun, can you check your hard copy for me? I'll get some pics later today and get them posted here. I know I can simply plug them in to find the hot after a good warm up period but that will only tell me what's hot and what's ground. There are four wires in total and on two fans. IIRC, each fan has a separate color coding for the wires.
Gomer, I found this tip in Nissan ASIST:
Symptoms: Engine overheats. Radiator fan fuse link blown, fan blades melted. Field fix: Repaired "BR" wire from E19, pinched by left headlight (also, check around radiator core support). See pages EF & EC 314, 315 for wiring diagram & component locations (in 1993 Sentra service manual). It is also page 315 in the 1994 service manual. |
Problem is I burned up my daily downloads looking for p315 in the 94 service manual. Can we get a listing of pages for each section of the manuals listed under the section titles?
There she is. Thanks a bunch, M.
This is a horrible service manual...you can't follow anything, and it is impossible to find 3 simple wire colors.
