p1336 code
I have my engine running good now after changing the iacv and air charge temp sensor,but after changing the crank sensor i still get the p1336 code.the car runs great any ideas how to check if the ccrank harnessis broke or if it is the other crank sensor? Ive heard that a bad starter or weak battery can cause that.my battery is charged and the sttarter turns over good.
There are two crankshaft position sensor. Which sensor did you replaced?
The P1336 code is for the crankshaft position sensor (POS) located on the oil pan facing the gear teeth (cogs) of the signal plate (flywheel). The sensor it's by the front engine mount. The image shows the transmission oil pan. http://x.nissanhelp.com/forums/attac...1&d=1352682798 |
thank you for replying but i cant figure out how to view when someone posts on here
pos sensor
yes that sensor in your picture is the one i replaced. i put the code out and it comes on fairly soon after running,but the car runs great no misses or idle problems
