98 pathfinder knock sensor
Hi folks,my 98 pathfinder has started pinging going up steep hills lately.
I tried higher octane gas=no help. I've read that a bad knock sensor could cause pinging?. I don't know how to check the ks, and i read it is nearly impossible to get to?, i recently cleaned my throttle body intake with o2-safe spray, with engine off'. i put a small piece of wood to keep the throttle plate open while i sprayed/cleaned the intake and plate. I read later on, not to touch/mess with the throttle-plate. my motor still runs smooth and no eng/lights come on the dash, but now the motor takes a few extra minutes to idle-down to normal= 650-750rpm's. i tried disconnecting the battery for a while but it the ecu won't re-learn -idle. could this have anything to do with the pinging sound? today i checked one spark plug=burning a little yellow and white.. i also checked distrubutor cap=looks okay and cleaned the rotor up...any info would be appreciated. Thanks. |
When was the last time you change the plugs and wires? |
Hi, timing belt changed at 105k now vehicle has 134k. same time changed plugs w/platinum tip ie;should still be fine?. not change wires, cap looks good, rotor a little burnt at contact but i shined it w/emery cloth still works good. it has taken up to 6-9
minutes to idle down even on 70 degrees morning start up. I noticed the idle problem immediately after the throttle body cleaning, and i eve double checked tightness on all intake boot clamps and hoses when re-intalling intake assembly. ps; after the vehicle warms up/idles normally, it performs as it always did. the recent pinging has got me concerned. i will try chevron gas and some fuel additive soon, today i drove to town up down mtn road some of it steep,, and listened for pinging,,i can still here it some when starting to accelerate up hill. |
Yeah, knock sensor will not make it ping. What the knock sensor does is send a signal voltage to the ECM when the engine pings or knocks and the ECM, in turn, retards the ignition timing slightly to help minimize engine damage. Yes, it is a pain to get to as it is bolted to the top of the engine block; the intake manifold has to be removed to access it. Some people have purchased a new knock sensor and a subharness for a Maxima and relocated the knock sensor to the top of the intake manifold for better accessability and to avoid having to remove the intake manifold. I would think, though, that it probably gets a better reading from the top of the engine block. The Maxima subharness does have to be cut and soldered to the original knock sensor circuit to complete the bypass. Some reasons for "pinging" can include a lean mixture or carbon buildup on top of the pistons.
