Hard/No Start
Anybody eperiencing a intermittant Hard start on the 2011 Juke.Extended crank time with no engine light.Please advise.
Not a common problem, but there is a bulletin with JUKE when there are more intelligent keys inside that can cause a no start situation.
Do you smell gas outside the vehicle?
Yes you can.I am aware of the fuel pressure sensor being recalled for leaks.
Thanks.I was thinking the same.The thing is I beleive on start up it would be the electric fuel pump(70psi) supplying the fuel.I have 70psi while the vehicle is displaying the symptoms,extended crank time and rough idle once it started.My tech support in Toronto can offer nothing at this time.I have three Jukes now with the same concern.I'm puzzled.
Has the recall been done on this yet? |
No.I have no details.All I know is I have a essential tool coming(Torque Wrench adapter) beyond that the Tsb is still in being developed.This info is provided through my dealer portal.I reason I want to discount this Recall as a cure is through my conversations with tech support The bulletin was never brought up.We'll see,at this point I suppose I should wait and see .
Thank's.I'm in Nova Scotia.I update my assist nightly.I looked at my assist just now and the recall hasn't been posted yet.I know that some gaskets will be drop shipped to me however I have no torque spec on the sensor.I should mention that I haven't smelled fuel.The owner has.Any conversation I had with tech line envolved the extended crank time/rough idle.At this point they are looking for my help in getting a snapshot of data with the C3 plus while displaying the symptom.Also the owner of one unit has supplied me with a short video clip with sound of the instrument cluster while the engine is cranking over and not starting.
I e-mailed a copy of the recall to you. |
Juke Hard/No Start
What is the Hi Pressure fuel pump reading PID on the scanner for a 2011 Turbo Juke, Also the the PID for the fuel rail sensor
