2002 QX4 O2 sensors and MAF
Evening,
I recently purchased my first Nissan - a 2002 QX4 with 130k. I'm happy with my purchase overall, but unfortunately the service engine soon light came on when I started it today. I pulled the codes and the truck is reporting all of the oxygen sensors are bad. That sounds pretty unlikely to me. P0031 (O2 Sensor - Bank 1 sensor 1) P0037 (O2 Sensor - Bank 1 sensor 2) P0051 (O2 Sensor - Bank 2 sensor 1) P0057 (O2 sensor - Bank 2 sensor 2) P0158 (Faulty Rear Heated Oxygen Sensor Bank 2) I know there's a TSB out to replace the rear oxygen sensors and reflash the ECM so that it does not heat up the O2 sensors as much/as quickly, but I'm not convinced that all four sensors failed at the same time. The QX4 feels like it's running rich. Acceleration is normally smooth (very smooth) except between 55-70mph, there's some hesitation and vibration/sluggishness from the engine. I don't know what kind of gas was run through it prior, but I've put two tanks of 91 through it. I did put in a small bottle of Lucas fuel treatment (not sure if that was a good idea or not). So, here are my questions - first, any thoughts as to the real cause of all of the O2 sensor codes? Would it be worthwhile for me to replace the MAF (using Maxima P/N 22680-2Y001) and see if that provides any improvement, or am I resigned to replacing all of these sensors? Thanks in advance for any help! |
P0031: OBDII Code P0031 INFINITI - HO2S11 Heater Control Circuit Low | Engine-Codes.com
p0037: OBDII Code P0037 INFINITI - HO2S12 Heater Control Circuit Low | Engine-Codes.com P0051: OBDII Code P0051 INFINITI - HO2S21 Heater Control Circuit Low | Engine-Codes.com P0057: OBDII Code P0057 INFINITI - HO2S22 Heater Control Circuit Low | Engine-Codes.com p0158: OBDII Code P0158 INFINITI - HO2S22 Circuit High Voltage | Engine-Codes.com All thoses could be set by a blown #25 fuse. http://x.nissanhelp.com/forums/attac...1&d=1328579944 |
NissanTech,
Thank you VERY much for your reply. I pulled fuse 25 this morning and sure enough it was blown. Replaced it and reset the SES using the 'gas pedal' method. Things are looking good so far. I've ordered a new MAF to see if it helps with the hesitation between 55-70mph. Thanks again. Very helpful. |
I drove around town and made a few stops today - when starting my car to go home the SES light came on again. Same codes as before, and the fuse was blown again. I'm going to try to look for a visible fault with the wiring to the oxygen sensors tomorrow. If anyone else has ideas, let me know.
