Transmission Fluid Check
Is this a Dealer item, checking the level?
Since there isn't a Dip stick, how do you check it? Thanks |
at the lower left corner of this page is a list of "Things You Can Do"
click "get the service manuals" select the model & year see page MA-22 for transmission fluid level check procedure it's easy to do, but the instructions are very specific - be sure to follow them carefully |
There Isn't a dip stick Or filler tube
Look at the model year, I ask about it is 2007 model.
Thanks |
1) see where at the lower left corner of this page is a list of "Things You Can Do"? 2) click "get the service manuals" 3) select the model & year 4) go to the "maintenance" section 5) see page MA-22 for transmission fluid level check procedure 6) it's easy to check the level, but the instructions are very specific - be sure to follow them carefully |
I have the manual MA-22and it Doesn't
It says , you need some type of filler adaptor
The dipstick is on the passenger side of the engine compartment. It has a black top with a silver sticker on it. It is held in with a bolt with a 10mm head.
Dip Stick
mpe235
(The dipstick is on the passenger side of the engine compartment. It has a black top with a silver sticker on it. It is held in with a bolt with a 10mm head.) Thank You, I Really didn't understand, Till you said where it was. I was told , that there wasn't a way to check the tranny. And at my age, Ha, I am a little slow, but I get there , just takes more time. Thanks Again |
glad mpe235 was able to help were you able to get the level checked OK? dryart |
Ok yes, It finally soaked in. Very easy, when you understand it, Ha.
Thanks for all your inputs, I am just slow , I suppose. |
