dougde |
08-31-2011 03:53 PM |
PO455 evap code
Hello, My '05 pathfinder is displaying a EVAP PO455 code (large leak). I've replaced the gas cap and visually inspected the lines and they look like they are in good shape. I did notice significant corrosion (green in color) on two aluminum colored lines (fuel lines?). It looks like they were covered with a piece of rubber 2 in wide and fastened with zip locks. The corrosion has eaten through the rubber. If these are leaking fuel lines can this result in the PO455 code?? thanks
