06 sentra long crank
I have a 06 sentra with around 47,300 on it. its starting to have long crank every once in while when i try starting it. I was woundeirng if i get fule pump repair kit would that fix it?
Yes, the fuel pump repair kit will fix it provided that your long crank time is due to fuel pressure bleed down. My sister's 03 Sentra had the same issue and it cured her problem.
long crank
hey
I got the fule pump repair kit done on my 06 sentra and it still has long crank. dose any one have any other ideas what it could be. |
check corrosion on all battery connection
