2005 Altima - P0335 and P0725 errors
I have recently been experiencing problems with my 05 Altima. Driving on the highway I noticed the engine felt like it slipped and then MIL came on saying service engine soon. Im getting codes for CKP sensor(0335) and engine signal speed(0725). Now when I try driving the car its fine for sometimes a couple of minutes then the engine cuts out and the steering freezes up. Needless to say this has put me in some very dangerous situations. Any ideas what could cause this? I would just take it to the Nissan dealership since its well under warranty but I am in the military and stationed in England and the dealership is not honoring the warranty and will not work on imports(US spec cars). Correct me if Im wrong but how much difference is there in an US Nissan and a English one. Any advice would be greatly appreciated.
I have the same problem with my Sunny-Sentra 2004 manual transmission the MIL light alawys ON the code is 0335 crankshaft sensor it can not be erased from Memory while driving the car is fine ,but sometimes the engine freezes while shafting gear ,also sometimes when I turn off the engine it doesn't start easily it takes long time to start again .I have tried to search in internet to find service Manual and the Location for Crankshat sensor but I have not find any thing to solve problem
Sounds like you both have a bad crankshaft position sensor. It is located on the backside of the engine.If you take the air cleaner duct off you can see if from the top. Look down where the transmission and engine meet. You should see the connector right next to the engine mount. For the sentra it is easier to see from under the car.
I am getting the same code with my girlfriend's 03 Altima - it has all the recalls (which was an ECU upgrade, not the replacement of teh crank position sensor). It drives fine with the exception of some rough shifting.
Anyway - I am getting mixed advice as to which sensor is the real problem. The check engine light came on and we checked and got both these codes. Seems unlikely both sensors failed? A Nissan tech recommended replacing the crankshaft position sensor as this fails more often, but I have heard the opposite elsewhere... Anyone know for sure? One thing noticed is that the shifting got rough at the time the light came on and I heard this could be an indication that the vehicle speed sensor is the problem.... Thanks for any advice!! |
The crank sensor monitors engine speed. That is why you get the engine signal spped code. Sounds like you may be getting that confused with the vehicle speed sensor. The crankshaft sensor is the one you will want to replace. I have replaced several for this same problem. It is a very common problem.
OK, Thanks for the advice - the crank sensor is like $25 - I'll swap it and let you all know how it goes.
PS - do I need to reset the computer codes afterwords? Or does disconnecting the battery take care of that? |
Disconnecting the battery will do it but it usually takes a long time. Just stop by an auto parts store they will usually clear them for free.
I'm having a bit of trouble spotting the sensor - i found the cam shaft position sensor right next to the air duct, but all the wires and connections i can see from above seem to connect to the transmission. If it is on the backside of the engine I am guessing it best to get to it from under the car?
Thanks! |
You will not be able to see it from under the car. You probably aren't looking down far enough.The wires come from the underside.
Jeez I spent an hour looking everywhere imaginable with no luck. This is the '03 4 cyclinder automatic model by the way...There are 3 sensors accessible that are pretty low but none are a match and all plug into the transmission. I can't really see around to the backside of the engine - but from under the car I could see a little and saw no sensor. I may have to give in and let a pro figure this out... |
I found the sensor but I cant get it unpluged, can someone please tell me what the trick is to unplug it? Thanks
Sensor Troubles
I had the issue where my Altima would occasionally skip or rev high for a moment and was getting the P0725 and P0335 codes. This morning I replaced the camshaft sensor and the car was hard to crank afterwards.
I drove it a short distance with no problems after ti did crank, but now it won't crank at all. I didn't make any changes except that sensor - anyone have any ideas? |
Oops - wrong sensor!
Thanks for pointing out that I replaced the wrong sensor - it really bites to slip like that and go down the wrong path.
I've got the right part now and am downloading the manual section that refers to it to prepare a bit better this time. |
Nissan charges to replace sensors
BTW, the dealership in question is Bankston Nissan in Lewisville, TX. I would recommend avoiding this location. I've asked them on several occasions to please contact me to discuss matter. No reply! |
