high idle at the start...
what may be the cause of high idle during start especially when the engine is cold it reaches to 1.5 rmp for about 10 + min then it will return to normal idling..by the way my car is 1995 nissan sentra, she has no problem at high speed, I've already ask some advice from our local mechanics but they can't find the trouble is it normal to have very high idle at engine start and wait for about 15 min for me it is abnormal..I'm praying that you can give advice thank you very much...
I would check you MAF and IAT. It's normal to start around 1500rpm but it should start to slowly go down after about 2-3 mins not 15. Is you engine taking a long time to reach normal operating temperature?
thank you very much for your reply, we will check our MAF and IAT. What is the normal time to reach normal operating temperature sir? thanks
Temperature gauge is very normal and we have just cleaned the MAF as you have advised and my idle is back to NORMAL thank you so much sir..Nissanhelp is the best...one more thing sir where is VTC is located in my 1995 sentra b14...thanks and more power
should be right next to the PCV valve at the back of the cylinder head.
