05 Oil Pressure Gage maxed!
I have a 05 Pathfinder LE
The oil pressure gauge is pegged at the highest possible point as soon as I turn the engine on. Its not a gradual climb, it jumps up there at start up and doesnt move. I assume this may be a sensor, the gauge itslef, or.....???? any help is greatly appreciated. |
Replace the sender
Google the sender and you will find it from $60-$80. It's on the bottom right front of engine. |
cool thanks!!!
oil sender?
is that what its called? |
Here's a link: Nissan Parts, NISMO and Nissan Accessories - Courtesyparts.com |
just noticed this happened to mine. Do you think this is a "fix immediately" type of a problem or more of a "get it done when I have time". I am very consistent with my oil changes.
Shop around, get the best price on one, and then change it next time you're under the car doing an oil change. I think there's an "Idiot Light" on the dash in addition to the gauge so you'll still have a warning if the oil pressure drops to an unsafe level. |
05 Pathfinder oil pressure switch
Just a heads up I purchased the switch off the internet for less than 15 dollars. Not sure but they all look the same to me. The 80 dollar part looks like the 15 dollar part. Anyhow it took all of 20 min including jacking up the car. I am no technician anyone can replace this part if you dont mind getting a few ounces of oil in your face who knows it might be good for the skin. SO for 15 bucks I fixed something that has been broken for 2 years and it is kind of an important thing to know your oil pressure. These vehicles have U-joint issues (I have replace the front now I need two in the rear replaced) they have issues with fuel tank sending units that was expensive. They have issues with the transmission cooling lines inside the radiator leaking and getting antifreeze in your transmission fluid. I replaced the radiator with an aftermarket that cost about 100 bucks through eBay. I did that 5000 miles ago I have 105000 on the vehicle now and it is an 05 Pathfinder SE 4x4. I am pretty sure I have all the common defects fixed these vehicles have. I was a Nissan dealer until I retired from that business 3 years ago. It is a good vehicle once you get these things remedied.
I recommend replacing the oil pressure sensor with a genuine Nissan part when it fails. I have read several posts at a Pathfinder site where people have replaced the sensor with an aftermarket replacement part only to have it not work right out of the box or fail not long afterwards. The oil pressure sensor was used in the early years of the R51, then around 2007 or 2008, it was replaced with an oil pressure switch, rendering the oil pressure gauge into a "dummy gauge." It'll either read halfway when the oil pressure is good or will read nothing, if the oil pressure is too low or there is a bad switch/circuit. The sensor is much more expensive than the switch. This all said, even if you have the early type sensor with an actual functioning oil pressure gauge, you will rarely see much movement of the needle; the only time you might see the needle position anywhere other than about halfway on the gauge is when you start the engine cold, in which the needle may read a little higher than normal until the oil warms up.
