DTC p1701
Hello I am a old mitsu tech converted to nissan and in a new world,any way I have a 03 murano sl 2 w with a code p1701 Tcm-power supply code and and it feels like it has a miss under a forward load. does any one have a idea or direction I should go? will be greatful for any help...:
Welcome to Nissanhelp.com!!
That code is triger when the power supply to the TCM is cut off. Just make sure the TCM connector and battery terminals are secure and tight and reset the light. If the light comes back ON then one of the 2 wires that supplies power to the TCM may be broken or loose. |
problem still there
Ok,checked all power, plugs and grounds cleard code and rechecked for codes and none at this time. BUUT it still has a miss feel only when in drive under a load, won't do it in reverse, park or neutral. sitting still will rev up smooth. talked to nissan rep and said possible trans problem. who knows I don't. any help will be great...Thanks stroked.
P1700
SBDS Interactive Cod Transmission Indeterminate Failure (Failed to Neutral) |
