Install Harness for 7 pin trailer and electric brake control
Hello all ..I am a "NEW" member here so hope I have things correct .
2008 Frontier 4wd Crewcab. I have purchased the electric brake sub harness and the 7 pin wiring harness from the Nissan dealer ... Very little instructions in the packages . I presently have the 4 pin trailer harness installed .Question ...Do I need to pull the passenger side panel off to change or add relays for the 7 pin harness? Parts man at dealership was unsure and technicians were unavailable at the time . Also the electrical brake sub harness ... I assume it is connected under the dash ....I see only one empty connector on the truck ....can I also assume that that is where it goes ? The brake controller is Accu trac 80510 by tekonsha ...On their website they indicate NOT to hook up wires by matching colour.....they give a cross reference chart ... from OEM harness to their controller harness ....any one have problems with this matching ? Is it recommended to disconnect the battery cable while doing these hook ups ?? Thank in advance ....much appreciated and am sure this will be a regular site that i come to ...Love the Frontier Marvie |
The wiring and relays in the passenger kick panel should be the same for either harness. Just install the rear portion. When you get done just check to make sure you have 12 volts at the pin in the connector. If you don't you should just need to install a relay in the existing harness in the kick panel. The brake controller plugs in under the dash. There should only be one connector that it can plug into. Be sure to follow the diagram supplied with the brake controller to wire it to the nissan plug. The colors are not always the same. There is no need to disconnect the battery.
Thanks mpe235.. just wanted to verify my thoughts ...
2012 Pathfinder 12v not at pin connector
Under the hood there is a small black box that contains three holes. one labeled trailer 1, trailer 2, and coolant pump. trailer 2 needs a relay plugged into it to have 12volt power to the rear of your vehicle. Read this post. I put some different instructions on the end of the post but there are some part numbers for your local automotive store that might be of some help financially.
http://x.nissanhelp.com/forums/diy-p...athfinder.html |
That is the answer I needed. I guess I just go to the parts department and get the relay and hopefully, I'm good to go. I saw clearly where it is marked "trailer 2" as you said. Thanks again, Ken
I got the brown relay from the parts department today and plugged it in Trailer #2; and as you said, the 12v is now hot. My previous vehicle used a 10 gauge wire and the harness wire seems pretty small. I wonder what that 12v wire actually handles. Is it enough to activate the brakes if the breakaway engages? Is it enough to maintain the trailer battery charge level? Thanks again for solving my problem!
No problem man. The brakes engage on the breakaway by using the power from the battery on your trailer. It wont matter about the 12 volt supply line coming from your vehicle at that point.
Does the 12v line maintain battery level in the trailer? I understand that it absolutely will not charge the battery, right? Ken
Wont charge it much due to the low amperage but should maintain it while towing. Go to harbor freight tools and pick you up one of those seven to ten dollar battery trickle chargers or battery tenders. Just leave it on or put it on a timer.
Great info from AB1748.
I just wanted to chime in a state my 05 KC Frontier LE does not have the same fuses under the dash and the relay box up in the engine compt also looks different than the photo's shown. There was also two brown and 1 blue relay in it already from the factory. |
Yep that was kinda my point as there is a difference between the Frontier and the Pathfinder. Although I have two relays up in the under-hood panel they're not the tow relays. My 2005 FSM shows the relays under the hood but it calls out two different connector numbers for the same relays. E227 & E228 in the wiring diagram for the tow relays vs E140 & E148. we both know the E227 and 228 relays are the ones installed by the "kit" in the wiring in the r/h kick-panel and I have no clue where the E140 and 148 relays are and at this point assume this is a typo.:peace: |
When I was trying to figure this out, a Nissan technician (aka mechanic par excellence) pointed out that relay is under the hood on the 2012 (after not finding it behind the kick panel).
