2005 Maxima...ABS/SLIP/TCSOFF/BRAKE lights and brakes make grinding noise after 15min
I just bought this piece of crap and having issues with it already.
First, brakes work fine for about 15 - 20 minutes, after that, they start making grinding noise when I brake on low speeds. Second problem is that, ABS/SLIP/TCS OFF/BRAKE lights come on every few minutes on the dash. Third, SLIP light blinks even when I make small turns and it feels as if the car turned off eventhough it's on. PLEASE HELP!!!!!!!!!! :dontgetit: |
You have a problem with the rear abs sensors. Get it fixed asap or it will get very expensive. They can damage the abs controller which cost $1300.00 just for the part.
I'm guessing you mean fixed as in get it replaced?
And which side is it? Rear passenger side or rear driver side? |
I got a reading from the mechanic and he said ABS MODULE needs to needs to be changed. Was he right or just trying to rip me off? Dont you have to change the ABS module only if the ABS/SLIP/VDC lights are constantly on? Mine go on and off.
Also, my odometer stopped working today. RPM meter works fine. Just the odometer won;t work. Sometimes it starts working itself. |
Had the same grinding, ended up replacing my ABS pump... my advice is get rid of the car before your transmission goes, I'm on my third one and it seems to be a common problem with the 04-06 maximas
I'm having the same problem, I recently bought a 2005 Maxima SL
just after 3 months I started getting this humming/vibration sound and when I braked I would get this loud grinding sound. I had my rotors machined, then I also changed my brake pads, but still the same thing. I brought it to a mechanic and was told my rear wheel caliber was faulty and that it was causing my wheel sensor not to read correctly and they replaced it. It worked fine for about a week, then all of a sudden the slip light would blink very quickly, if your not looking you might not even notice it. Then the ABS and VDC light would turn on and the grinding noise kick in, but this time it would only happen once, it doesn't make the grinding sound again after that, but the lights are all on in the dashboard. What do I need to do to fix this problem any suggestions. Thanks |
Thanks a lot I've already spent a little over $800 on things that didn't fix the problem,
from getting rotors machined, to getting new brake pads and changing the wheel caliber. I will never get another Nissan again after this problem. |
[GVIDEO][/GVIDEO]
