please help p1320 p0300
somebody must it seing this before a costumer came to the shop 01 maxima with p1320 and p0306 ok check it out coil 6 not working so according to nissan tsb we did all 6 coils and plugs car ranned fine for two months costumer comes back saying that is missing again so with out hesitation replaced all coils and it kept doing it so we scannded p1320 p0300 m ok check signal and everythings is there power, ground and the third one from the ecm its missing and at that time all 3 cilynders in bank 2 2 4 6 stop working car runs on back cilynders check crank sensor reff crank sensor poss and cam sensor ignition condenser they al passed and still got all neww sensors and still no signal to the coils from the computer even took timming cover off what a b thi nking it had jump timing and again everthing its fine there check continuinty on wires from computer to coils check fine bottom line replaced everything exept ecm please help
ignition relay??
ignition relay thats powwer to the coils and its there on all six coils just the front cilynders have no fireing signal from ecm
Hello I have a '95 GLE Maxima,Blk w/18's! It also has this problem.
So did you try replacing EGI/ECM Relay? If so,Did it correct P1320 problem? As you're on ur search to soon bring closure to this can you post and update corrective action |
regulator and plug it,Then on ign. and test fuel pressure there should be around 40psi. Any lwr. than that replace fuel pump. O! and did you try replacing all six injectors? These are known commonly to eat injectors like crazy due to it's side feed design.It overheats over time. |
