Starter relay--1992 pickup
No power to starter. Some time ago a repairman repaired a relay in the starting system. I believe this is the same problem, but I don't know how to identify the relay in order to replace it. 1992 pickup, 4 cyl., 5-speed manual trans. Can anyone help? Thanks!
Sorry,our tech manuals don't go back that far however the relay box is located under the hood and the cover should be marked.You should also check all the connections starting at the starter to insure a good connection.Check to see if you have voltage at the starter.It's possible that the starter itself is locked up.And don't rule out a blown fuse or bad ignition switch.
Right behind the battery, blue double relay. Part number 25230-89981. When in no start situation have someone tap on relay while trying to start engine. If it starts the relay is safe bet.
Thanks for the helpful posts!!!
