'99 Maxima clutch bleeding
where is the slave cylinder?
Mounted to the transmission case.
How do I bleed the clutch slave cylinder on my 1999 maxima and where is it located?
The clutch slave is mounted on the transmission on the drivers side of the engine compartment. You will need to remove most of the air intake piping from the front of the car to the air filter housing to get at it. There are two bleed valves; one on the slave itself and one on a junction box on the shock tower. I have no idea why the arrangement is like this instead of a direct line from the clutch master - but there it is. Good luck; I have always found that bleeding this clutch system is a PITA.
Thank you very much for the quick answer. I really appreciate your help!! I will start on it this PM. What bleed valve is the better one to use? It will easier to use the top one, if you recommend to do so. I had found a large bleed valve between the top of the shock tower and the air filter box, but I was not sure what it was for, since the I could not see where the metal line going to it came from. I have not been able to find where the brake fluid leak is, which is a puzzle?
Excuse my ignorance- What is a "PITA"? Thanks again. |
Clutch worked fine one day. Next day after 10 mile trip car was parked for 8 hrs and when I returned, clutch pedal went to floor. I can't see where leak is without jacking car up. Unless you advise differently I will bleed from top valve and see if I can find the leak. Possibly if I jack car up I might find the leak after bleeding. What do you advise?
I can send you the "clutch" section of the FSM if you send me an email address. |
I could use the clutch FSM. I need to know what the part (hose with bracket) is called that goes from the slave cylinder down to the engine mount. I have a leak where the rubber hose is crimped to the metal collar. I just replaced the slave cylinder only to see fluid weeping from the hose.
[email protected] |
http://www.partswebsite.com/nissanpa...=11&type=parts You probably want the "Flex Hose, w/o bracket" but hard to be sure w/o a picture. One thought - go to your local dealers parts department, have them pull up picture, and see what they call the part. Or go aftermarket. Check out this link for a "full lenght" hose from master all the way to slave. I bought one and hope to install in the next few weeks. http://www.racetechperformance.com/ProductDetails.asp?ProductCode=310-0154-42 They also have the short link to replace the OEM part only. http://www.racetechperformance.com/ProductDetails.asp?ProductCode=RNC%2D210 Good luck. |
