opening fuel cover door
fuel cover door fail to open . I am running out of gas. Please, help
You have release lever for gas door? Open the trunk and pull back the trim on the drivers side, you should see the release cable for the door. You should be able to remove the cable and release button from the body. Unless the door is seized than you would need a 2nd person to pry door open while pulling on the release tab.
Thank you. Now it is take two people to open one small door. The door has small spring to let door pop up. This spring is broken and need to replace. Nissan dealer told me it is $7.55. I will put order on Monday.
Does anyone know how to open the fuel door on a 1997 pathfinder?
