Walt84 |
09-21-2009 05:35 AM |
2000 Pathfinder Headlight Bulb Replacement
I'm having trouble changing the headlight bulbs on my 2000 Pathfinder. I've read the instructions in the owners manual; however, the graphic doesn't match the headlamp assembly. There is very little room between the headlamp assembly and the air filter housing on the DVRS or the battery on the NDVRS. Should I need to remove the air filter housing and the battery to replace the headlamp bulb? Does anyone have pictures of this procedure? I've replaced bulbs on several makes and models including my '96 Nissan Maxima with no problems. What am I missing on my Pathfinder?
