cat problem P0430 code
Keep getting P0430 code on bank 2, catalyistic effeciency low. . .or something to that effect. I had the cats examined and they are in excellent shape. No need to replace. I had the fuel rail pressure checked and it was fine, both running and off. I beleive I have a computer issue in the fuel curve. My o2 sensors seem to indicate it. Bank 1 sensor 1 runs around .31 mV + or -. The oppisit side Bank 2 sensor 1 runs .62 mV. That seems to be twice as high. Bank 1 sensor 2 is .59 mV and bank 2 sensor 2 is .65 + or -. Bank 2 side seems to be running rich, and that is where the code comes from. If it had less fuel to burn, then wouldn't it take care of the efficiency problem. The cat seems to be getting too much fuel to be efficient. How can that be corrected? Ecm reset or reprogram? 2005 with 26,000 miles. I would like any help as to how to get my nissan dealer to help me. Not to mention it might help with the mpg of 11.5. I would like to see 15. The truck is all stock. No mods of anything. Help please. Thanks. .. Josh
You are covered by the 8 year 80,000 mile warranty on the convertor. If they found code p0430 they should have replaced the cat. The manifolds crack and can cause irregular readings on the sensors.
Ok on what you are saying. Even though the code indicated a cat problem, the convertors were ok. If it was to be assumed that the cats were ok, where would you go next? Thanks for the response. .. . Josh
Will look into the line graph pattern. As far as the rear sensors after the cats are concerned, do the rear sensor readings affect the sensor readings of the front sensors. The voltage readings of the sensors off the exaust manifolds read a .31 mV on bank 1 side, and .62 mV on bank 2 side. They seem to be quite different for opposit sides of the motor. Curious on that. Thanks. . Josh
Good to know. Looks like that will require a little work to get a good look at the manifolds. Even more work to get loose to replace them if needed. Could you tell me which sensor voltage looks like the correct one on a 5 wire wide band sensor? Either the .31 mV or the .62 mV. I figure the lower voltage is the ok one, but not sure. .. . .. Josh
Ok. I do greatly appreciate the help. I was having trouble getting answers and places to begin at looking for the problems. Wish I could send the whole truck your way. Thanks again. I will be back with questions and results.. . . Josh
p0430
So here I go. I went ahead and replaced the right side catalytic convertor. I even replaced the 5 wire sensor, and the down stream 4 wire sensor. I did all that and the problem is still here. It won't go away. I get the p0430 cat efficiency code. I still think it is the ecm and a fuel map problem. The numbers show that the right side of the motor is getting twice as much fuel as the left side. Why is that? I get a reading of .31 on the left side, and a .60 on the right side. Both those are the up stream 5 wire sensors. No reset has ever fixed it. Is the fuel pulse width on the right side adjustable? Can you direct me towards the right place to address this? . . . Josh
help
2001 sentra 1.8. I have the code to and the car runs rough. Sometimes jerks. I know it uses about a pint of antifreeze every 3 weeks to, so I don't know if I have a head gasket leak that would affect the way its running and set this code
your 11 mpg is telling me that your air/fuel mixture is too rich... and its throwning the p0430 code.
best easy procedure is to disconnect your battery for 1 hour.... re-connect.... start engine and your ecu will be under air/fuel re-learning procedure..... 5 minutes to warm up engine.. no stop lights or stop signs.. you must go on open flat highway... keep rpm's at 2,000 . bring truck to 60mph and keep it at that speed for 20 minutes... exit and drive the same way on your way back... take it easy on the gas for the next 5 days.. |
I have a 2005 Armada SE, at 160,000 miles. Last summer my truck started to act up the RPM would go really high when I pushed the gas and the speed wouldn't go up and I would bog out. I would pull off the road, turn my truck off let it sit for a minute and it would crank up fine. The service engine light never came on so I put SeaFoam into my gas filled it up and my truck started to run fine. Now, one year later my truck started to act up again the same exact way it did last summer. This time the Service Engine light came on so I went and had it diagnosed. I have the code P0430 that popped up twice but it's the same code (P0430) twice? Why is that and what does that mean? I'm really confused on why I would get the same code twice. If anyone could help me I would really appreciate the help.
