How to set timing 2003 3.3L
I know how to set timing w/ light but need to know how to set computer to diogostics mode as called for in the Haynes Repair manual. If I connect the OBD scanner, does this place it in the diognostic mode? Please advise. I'm simple so all the proper steps required would be helpful.
Thanks |
2 Attachment(s)
You don't need the OBD scanner to set the time.
1. Run engine at about 2,000 rpm for about 2 minutes under no-load. 2. Rev engine (2,000 to 3,000 rpm) two or three times under noload, when run engine at idle speed. 3. Turn off engine and disconnect throttle position sensor harness connector. http://x.nissanhelp.com/forums/attac...1&d=1243566196 4. Start and rev engine (2,000 to 3,000 rpm) two or three times under no-load, then run at idle speed. 5. Check ignition timing with a timing light. M/T : 10°±2° BTDC A/T : 10°±2° BTDC (in “P” or “N” position) http://x.nissanhelp.com/forums/attac...1&d=1243566196 |
Thanks for the help. I didn't do it this way so I'll check it tomorrow. Hope this is why gas mpg is poor.
Mike |
anwer
Only disconnect the lower connector at tps or two conectors for set time at frontier 3.3 L 2000 thanks
