2005 titan won't start
my 05' titan won't start...only clicks a couple of times...plenty of gas...checked battery and starter both check o.k....notice that with battery connected to truck and everything shut off(i.e dome lights etc.) the battery drains to about 10 volts...and yes new battery has been installed and tested good with load tester...anyone got any ideas...much appreciated
2 Attachment(s)
Sounds like starter, but you need to check if there is power at the starter while you are turning the key. If there is no power, then check the starter fuse
my guess is the starter, usually clicking noise point to the starter it may be that the selenoid on the starter burnt out. edit: uhhg beat me to it Will |
i already replaced the starter and battery...when key is in ignition and u try to crank the truck all lights on the dash light up as normal then the starter clicks 2-3 times and nothing...all lights on dash go out and gauges bounce a few times and thats it...
i read on another forum about the IPDM(what ever that is) that seemed to be givin people the same type trouble i 've run across...however they were saying the IPDM was dealing with the gas(i.e. tank level or fuel pump)...if i'm not mistaken the 05 titan that i own has a 28 gallon tank....but i've never been able to put more than 22 gallons in it with the fuel gauge below E and light on...
If you the engine is not cranking at all then there is a problem with the starting system. The IPDM is just a more sophisticated fuse box that holds relays (which are not serviceable) and fuses. |
Do you have an alarm/immobilizer in your car ?-that will do it.
How long before the battery goes to 10 volts? So both new and old batteries would drop to 10 volts? What do the battery cables look like, any corrosion on either end ? When connecting the battery do the cables "spark" when they touch the terminals? Have you checked for a draw on the system ( I only ask because of the dropping to 10 volts) ? Can you jump start it ?
I have had the same problem occasionally w/my 05 Titan. Sometimes it will click and all the gauges bounce uncontrollably then it will start, sometimes the gauges will still act up for a min after it is running. Once all it did was click and it wouldn't start. Went back to it later and it started right up. I haven't had it to the dealer to figure out what it is because right now the rear has gone out of it and I'm over the warranty mileage. Trying to see if Nissan will help me since I had the rear seal replaced prior.
If you see the gauges fluttering, get a new battery.
The battery test may say it is good, but replace anyway.
My 2004 Titan would not start, just turn over. I found that if I put the key in , turn to on, paused for like 5 seconds, then turned to start, it would turn over for maybe 2 seconds, then start up. All the gauge needles would then flutter, and my odometer trip meters would all reset. I pulled out the IPDM, replaced the ECM relay with one from a junkyard, but no change. Then I read that fluttering gauges = need new battery. Installed a new battery, and starts up like new! |
I just replaced the battery in my truck because to the very same thing that is happening to yours.Starters clicks and gauges jump around.All connections clean and tight and battery tested good untill it sat over nite.Had shorted cell.Replaced battery and no farther problems.Works fine and last along time.
Its a Battery Problem. From what I found out about working on cars is that a battery will test good if only 1 cell is bad. When 1 cell goes bad it will have the voltage there on the load for a little but because the load tester doesnt out a load on like actually starting the truck the will test good UNLESS you keep the load on it WILL drop. Starting the truck is such a big load it drops the battery instantly causing guages to get voltages and not get voltage relays usually clicking and the starter solenoid clicking. You can have a bad cell in a new battery off the shelf. Look at the made date not the shipped date on the battery. Could be 8 months old.
I see this problem was months ago. You should post your resolution. I hope you figured it out by now.... |
I just loged on for the first time with the same problem. But I jumped the truck and the indicator on board read good. when trying to start 05 le,the inicator board was freakin out even if I took the key out.once It starts Its good till the next morning.(with new bad).can we continue this discusion I will try changing fuse.
Maybe keep buyin' more starters and batterys 'til you find the combo that works? :hmm: |
titan starts then shuts off after 2 seconds stalls then won't start again for several hours
i am looking for someone to help me out. i have a 05 nissan titan that has 257,000 miles on it so i decided to rebuild the engine because it was smoking and bottom end was noisey. i finished it up and could only get it to start then it stalled out. as i continued to try to start it i get a very strong fuel smell. after a couple of hours i gave up on it for the day. the next morning i went out to my truck, same thing all over again. it has been to a local nissan dealer in my city and after 600.00 they tell me they thought it had jumped time. so i let them take the front of the engine apart at the sum of another 400.00 and they discovered that the timing is dead on. then at that point i told them to stop on it and i had it towed out of there. sense then i have had it towed to two different reputable shops, now 12 weeks later as it sits in my shop i come up no further ahead then i was when i started this project. all i have done is spend a ton of money and i still cant start it. can anyone help me please?
