02 sentra rough idle code p0300,p1111
Put a new headgasket in and now has rough idle and get listed codes any help would be much appreciated
was your head warped is that why u had installed a new gasket? 1st code is a random misfire, u want to make sure u plugged everything they way it was and tightened the head according to specs cause aleak can casue a misfire.
P1111 Intake Valve Timing Control Solenoid Valve dont much about this one but u can check out the engine control section of the service manual and find more info on it aswell as your other code here is the link Knowledgebase - 2002 Sentra - Nissanhelp.com |
can i ask you why did you change the head gasket ok: swap the coil's, put No. 1 in the No. 3 and put the No.4 in the No. 2 that way u'll know if one is bad or not
check compression on the cylinder's |
I would check the valve timing. poss. chain of by a tooth or two. Also make sure all is plugged in.
