1996 Nissan Altima error codes PO100 & PO325
Hello,
I have a 1996 Nissan Altima that is recieving error codes PO100 & PO325. The car has been idleing low and shutting off on occasion, any ideas on how to fix this? Thanks! |
Nissan OBD-II Trouble Code P0100
Nissan OBD-II Trouble Code P0325 dont worry much about this, i would try to replace the MAF first |
Hello,
Thanks for the advice. I cleaned the hot wire in the MAF with MAF cleaner, I will drive the car and see if that solved the problem. If not then I will replace. I will update the results, thanks again. |
